pianotuna's avatar
pianotuna
Nomad III
Jul 29, 2019
air conditioner without and with autoformer
Hi all,
Ambient temperature 73 F
Shore power 30 amp with no other person providing a load. No load voltage 117.2 volts.
Loads: Dometic Fridge, and Magnum inverter charger. No charging being done at the moment.
The Air Conditioner is equipped with a microaire unit.
No autoformer:
328 watts 117.2 v (fridge on 120 volt setting)
1367 watts 109 v recovering to 110.2
With Sola Basic autoformer
327 watts 117.2 volts
1426 watts 114 volts recovers to:
1501 watts 121.2 volts
After running for 20 minutes:
1750 watts 120.2 volts.
There is a difference in the sound of the air conditioner when I listen outside the RV.
I have tweaked the Sola Basic to do first boost at around 113 volts.
  • Damage to motor windings can begin when operating on 108V or lower
    I prefer AC Voltage above 110V under load
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
