joe0508
May 10, 2014Explorer
air conditioner
I am thinking about rechargeing my rv air conditioner myself.I am not sure which side is the low or high side.Will the can connect to both sides or will it only connect to the low side.
kaydeejay wrote:I have found some leak sealer that is supposed to work on metal lines as well as rubber lines it is called ac pro super seal your supposed to use it before charging it with ac pro refrigerate.joe0508 wrote:If the kit is worth buying it will give you a pressure to aim for depending on ambient temps - yes.dougrainer wrote:I assume the gauge will tell according to ambiant temperature.
OK, HOW much 134a are you putting IN:h Doug
If you have lost refrigerant, then you must have a (slow) leak.
You might want to find a can of R134A with leak sealer included.
No guarantees, (won't fix compressor seals) but it might help.
