joe0508 wrote:
kaydeejay wrote:
joe0508 wrote:
dougrainer wrote:
OK, HOW much 134a are you putting IN:h Doug
I assume the gauge will tell according to ambiant temperature.
If the kit is worth buying it will give you a pressure to aim for depending on ambient temps - yes.
If you have lost refrigerant, then you must have a (slow) leak.
You might want to find a can of R134A with leak sealer included.
No guarantees, (won't fix compressor seals) but it might help.
I have found some leak sealer that is supposed to work on metal lines as well as rubber lines it is called ac pro super seal your supposed to use it before charging it with ac pro refrigerate.
Yes, the Pro Super seal does work on small leaks. I do NOT know how it will work on a Converted system(12 to 134a). Your Gauge will NOT give you accurate pressure for a full charge. Even attempting to temp correct it. The Cheap(sorry, inexpensive) gauges have a large error factor on the needle read out. You REALLY need a Hi and Low side readout to charge. Better yet is to charge with the exact charge for your particular system. But, that is difficult to find unless the original charge sticker is still on or readable on your RV. Remember, TOO LITTLE 134a and it will not cool adequately. TOO MUCH and it also will not cool adequately and will produce extreme hi pressures. Just take it slow and watch your output temp on the outlet closest to the blower/evaporator. Run the engine at least 1200 RPM while charging. Make sure you have it on MAX or Recirc on the Dash control. A way to tell is to have a digital thermometer in that outlet and have someone inside reading out the temp drop. When you reach saturation, the output temp will start to rise. ONCE THAT HAPPENS, stop the charge. You are as close as you can get with your tools. Doug
