joe0508
May 10, 2014Explorer
air conditioner
I am thinking about rechargeing my rv air conditioner myself.I am not sure which side is the low or high side.Will the can connect to both sides or will it only connect to the low side.
joe0508 wrote:If you are going to attempt this, buy a refill kit that contains a shut off valve and a pressure gauge and follow the instructions.joe0508 wrote:It has been converted from r12 to 134a.It is a 92 p30 chassis with a 454 big block tbi
Altern wrote:marcsbigfoot20b27 wrote:"A man must know his limitations"....and the OP is in desperate need to know his...:)
If you dont have the proper tools or know-how to do the job, I would recommend taking it somewhere and have them do it.
If you do manage to hook up the high side to the can, you could end up with a blown up can......and a mangled hand.
AC work is not just "stuff a can in it". You need to have gauges and know what you are doing.
