joe0508
Jan 08, 2016Explorer
air conditioner
I have a ducted rv air conditioner.Its an air conditioner only no heating element.It has the thermostant on the wall.I was at the rv today doing some cooking.I had the generator running with the furna...
joe0508 wrote:DrewE wrote:The thermostat is near the kitchen and i had a lot of moisture in the air from cooking because the windows were steaming up.It does have a separate off switch.When you turn it on their is a green light that will come on.Just the opposite i turned it all the way down.The funny thing is the unit wasnt even in use when it happened.Are they supposed to kick on automatic like this when it get to warm even without a heating element?
Is the thermostat near the kitchen? Does it have a separate off setting, or did you just turn the temperature knob all the way up? Perhaps it was getting warm enough from the cooking to turn on. It's also possible that the thermostat is just plain broken/malfunctioning.
One sure way to prevent the air conditioner from running is to manually flip the air conditioner breaker in your electrical distribution panel. Usually there will not be anything else on that circuit.
