joe0508's avatar
joe0508
air conditioner
I have a ducted rv air conditioner and when i change the thermostat fan speed it stops blowing.If i turn the temp control up and wait for the compressor to kick off it will work as it suppose to.Does anyone have any idea what is going on or is this normal?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    When you change your fan speed it stops blowing... When you turn DOWN (not up) the thermostat (Cooler is DOWN don't you know) the fan comes on with the compressor..
    Ok, fans usually have either 3 or 4 settings on RV
    HIGH (Which I HIGHLY recommend)
    medium (optional, the 4th setting)
    LOW and
    AUTO
    If you change it to AUTO, you are describing normal operation
    IF your T-Stat is wired.. and it works on either HIGH or LOW as you feel it should (Runs all the time) but on the other mode it does not.. Might be a broken wire or a bad T-Stat. (or a bad relay)
    Mine.. Blows just fine, all modes.. problem is lost refrigerant in the coolign system, Been over 2 weeks with only one AC in this 38'er... And it's getting HOT again outside (the 1 week was record setting, EVERY DAY we set a new record for consecutive number of days over 90 degrees.. Eating dinner out cause I can't stand the heat in the Kitchen is getting expensive.)
  • magic43 wrote:
    It always helps to list your AC manufacturer and model.
    I dont know much about the air conditioner except that its ducted.I think it might be a coleman.
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 13, 2026
