Sitting in the trailer (smallish with single AC unit), after a long days drive, with ac on, as it is a gazillion degrees outside, and am wondering - why are the RV ACs so darn loud? I was up on the ro...
many rv AC units do have two fan speeds, Noise, well I agree, however there is a way to reduce the noise level dramatically. It does mean it is ducted only, but noise reduction is amazing.
Now the solution isn't inexpensive, but it is well designed. And if you install the unit as per the directions you will also get improved airflow
https://wackoproducts.com/
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
