B-52G's avatar
B-52G
Air conditioner
I just bought a new Keystone 5th wheel and am wondering if there might be a problem with my a/c. It is hot where we are and the air run most of the time, but I have noticed that it will shutoff for a few seconds and then kick back on. It will do this several time and then run fine again. I know in home a/c there is a switch that will not allow the compressor to kick back on for a few minutes to keep from burning the compressor up. Any help needed.
  • Our fan will stop for a few seconds and start back up, but this is when the fan is on automatic and it is just changing fan speeds.
  • Thank for the input. I did'nt thank it was acting right.
  • It shouldn't do that and since it's still in warranty, I'd get it fixed.
  • Make sure you check the VOLTAGE inside the RV with A/C running. If it is below 110 VAC the poor A/C is likely trying not to burn itself out.
    Many of us carry autoformes to correct for the low voltage found in many campgrounds, especially on hot days. Mines a Hughes.
  • If it is only a few seconds then it is not the defrost cycle. My compressor would drop off for a split second intermittently and my voltage gauge showed excellent voltage at the campground. This was the 4th campground on a 3 week trip. Back home now and I ran it several day on my hookup and could not duplicate the problem. I have not yet checked for anything laying against the evaporator or loose connections. I do notice that the thermostat variance is 2-3 degrees which is not normal.
    Haven't had time to dig into it any further.
  • Most times it will do this as a defrost cycle. It will use the fan to bring in warmer air to stop ice from being built up.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
