pianotuna
Aug 26, 2013Nomad III
Hi horton333,
I went with the Yamaha 3000 sIEB as it has a ten second boost of 500 watts powered from the unit's starting battery.
If you travel to the mountains you may find the one you have will no longer "do the deed". If that is the case there are three inverters that will "boost" using the RV battery bank (magnum, victron and mastercharge) I'd pick the Victron if my pockets were that deep.
Since you have offered to design one--put in a larger starting battery and a longer boost time? (or even more boost?). I would want 3600 VA instead of the 2800 VA that is in the Yamaha.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 18, 2026
