Laceygirl312's avatar
Feb 11, 2026
Air Hwh leveling system
I am looking for information on a 2004 Monaco Dynasty HWH air leveling system, my panel is dead, I can’t control anything. I have tried to reset and nothing, it won’t dump, won’t light up. The tag works air brake is on , next I am looking for air manifold. Any help on this sure is appreciated. Thanks in advance. Gary
  • Way2Roll is correct. It sounds like you have a “power” problem not a “manifold” problem. You need to get a volt/amp meter and start at the battery, and proceed to both the input and output side of the panel, and continue through all the control valves, switches, etc; and see where you have power and where there should be power but isn’t. But basically, it sounds like there is no power getting to the panel. This could be caused by no power at the battery, a blown fuse, disconnect switch in the wrong position, a broken wire, bad ground, etc.
    If you run wires temporarily directly from the battery to the panel does it then “light up”/function? That answer will clue you in on where to look next.
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 11, 2026
