wa8yxm
May 22, 2014Explorer III
Possible issues:
Partially opened tank outlet valve or clogged tank outlet strainer.
Loose clamp on any hose on the pump INTAKE side
Pin hole in any hose pump inlet side. (very low probability)
**SUSPECT #1** Pump inlet strainer NOT properly closed, or cracked due to not being properly drained. (Easily replaced).
Loose screws on pump housing allowing it to suck air (And I might add spit out water)
The above list is in water flow order.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
