I noticed today that my 1988 Southwind has no air coming from the dash vents when the blower is on. I removed one of the flexible air ducts from the chute that the blower is hooked to, there is what ...
As Roger said, there is a vacuum switch controlled by the lever or dial on your dash. It is quite possible that one of the vacuum lines has come loose from this switch behind the dash panel. Check here first. If all the lines are connected, then it could be the switch itself. This was the solution to the same problem when I experienced it. $35 for the part but about two hours of cussing and swearing to access the switch and replace it?
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
