I noticed today that my 1988 Southwind has no air coming from the dash vents when the blower is on. I removed one of the flexible air ducts from the chute that the blower is hooked to, there is what ...
You should be able to find either a Joiner (little plastic piece barbed on both ends) or even a piece of small tubing that will fit inside. Then heat shrink if you want to lock it a little tighter. If all you can find is a Tee, just plug the extra tap with a piece of tubing and a screw or golf tee in it.
But it sounds like you found it, fixed it and frankly you got away very easy. Providential that it was where you could see and work it.
