talotto
Jun 10, 2013Explorer
Best test is to swap it out and see if it fixes the problem. They're cheap, can't hurt to have an extra on hand anyhow. There are testers for them, but they don't test at the voltages and currents these are running at so they'll tell you if it's really catastrophically bad, but don't guarantee it's good if it tests OK.
As to where to get them - any air conditioning shop will have a variety, as will many electrical suppliers, some old fashioned hardware stores, and places like Granger Supply.
Best is to take it out and with you to the supplier and have them match it up spec for spec. They usually have wires that plug on to the terminals. Make sure you mark the wires, or take a picture, so you can put it back the way it was.
CAUTION: Make sure the power is off to the unit, flip off the breaker, etc. AND short across the leads with a screwdriver or knife or similar to ensure it has been discharged. They can hold a nasty charge for quite some time.
It's really easier than it seems to swap one out, usually takes more time to get to it than to swap it out.
Having RV issues? Connect with others who have been in your shoes.24,368 PostsLatest Activity: Mar 11, 2026
