- dhullExplorer IIOk after 45 minutes of Internet surfing I found my manual. Wow it has a page 2! Dealer only gave me page 1. And it says to push the mode button for 5 seconds. No wonder I changed it inadvertently. You'd think it would be a combo...
THANKS TO ALL - drsteveExplorerWhat happens when you press the Mode button?
Is there a remote control? - dhullExplorer IIDarn that did not work. Maybe it's broke cause I've tried every combo of the 3 buttons on it. Perhaps more info...
Thermostat is a 9430 series Airxcel by Rv products. It has 3 buttons, an up and down triangle to plus or minus the temp setting then a button beneath those to set the mode. None of the buttons are labeled but the owners manual refers to it by shape and calls it a mode button. - dhullExplorer II
Old-Biscuit wrote:
Changing Temperature Scale
Press both SYSTEM and MODE buttons in for 5 seconds.
Temperature changes from °F to °C or °C to °F
Apple Valley......
High desert?
Lived in Baldy Mesa until 2007
I'll sure try that. Maybe I didn't hold for 5 second's when last I tried.
No sir... Johnny Appleseed's stomping grounds, central OH - wa8yxmExplorer IIIGee that would not be a problem for me :)
By the way did you know your BODY is Metric? Yup 98.6F = 37C as I recall.
(I do the conversions mentally but I normally use a cheat (C to F, Double and subtract 10% then add 32) not as accurate as C+9/5+32 but close enough for most things). - Old-BiscuitExplorer IIIChanging Temperature Scale
Apple Valley......
High desert?
