SoundGuy
Feb 11, 2018Explorer
Bill001 wrote:
I found the specs for Running Wattage on this unit, but I have not found a power consumption value when the unit is on low.
Does anyone know that, or measured it?
You'd have to be more specific about your particular model as there are several versions of Coleman Mach 8 A/Cs. Also, RLA - Rated Load Amps varies depending on ambient temperature. If total draw is a concern you'd be far better off with a Coleman Mach 3 P.S. A/C.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
