moonlitsouls
Jan 09, 2021Explorer
theoldwizard1 wrote:moonlitsouls wrote:
I will be upgrading to lithium ...
it would be nice if I could find a charger converter that can control shore power, solar power, and that also has an automatic transfer switch to run the generator based on preprogramed settings
Not exactly what you are asking for but I think it is a better solution.
Get a new inverter/charger like a Samlex EVO-212 (it has charging profiles for flooded, AGM and LiFeSO4; other makes/models are also available) that has a built in transfer switch and automatic generator start.
Remove your converter. Connect the DC fuse panel, the solar charger and the inverter/charger directly to the battery bank.
You're done !
thanks a lot , samlex seems to be putting out some quality stuff, i looked through their products on amazon to see how theyre being reviewed. the EVO line has a lot of what i need!
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
