RLS7201
Oct 06, 2015Explorer II
I think "d3 = 2112, Throttle Position Sensor (TPS) below low" is a clue.
I've seen and repaired a similar problem.
Check the throttle linkage at the engine. There is a shaft and linkage that connects the throttle cable and the TPS cable. The shaft and linkage may be worn to the point of failure. It could cause erratic failure. That was causing TPS error codes on my customers 8.3 mechanical Cummins.
Richard
Richard
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
