Twomed
May 25, 2014Explorer
With the key on and engine running are the lights on in the trans shifter?? If no then you have no power to the trans control unit.
Not sure about the 100 series trans...BUT you should repost your question as Allison 1000 problem. That should get all the truck guys looking that use that trans, and maybe they can answer your question. Also search the Allison Trans forum on irv2.
Good Luck :)
Good Luck :)
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
