jayw900's avatar
jayw900
along the lines of an inverter charger
I was sitting here thinking, cause that's what i do, and have tried to do a search however it seems i'm not asking the right question.
Is there something that does the opposite of an inverter-charger? Instead of prioritizing shore power to battery, i'm looking for something that will choose battery over shore until the battery voltage goes below a user chosen set point.
For example, always running on battery(solar) until 12.0-12.1 volts when it switches over to shore power while batteries charge up to float(~13.2) then changes back to battery. All i need is a name or phrase and i can do the rest. The search i've done so far have only brought up "normal" inverter-chargers.
Having RV issues? Connect with others who have been in your shoes.24,332 PostsLatest Activity: Nov 05, 2025
