dougrainer
Nov 19, 2016Nomad
The system is NOT designed for Boondocking. It is designed for the most common RV operation--- In a RV park and the coach batteries will NOT be severely depleted, so they use that 1 hour time. What you could do, is, install 2 extra cables on each side of the solenoid with a cut off switch. When you want to do the full charge, close that switch and drive. When you get to your destination, open that switch. Doug
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 07, 2026
