MrWizard
Mar 19, 2014Moderator
sounds to me like its been rewired
the EMG start relay is usually NOT a continuous duty relay and would normally burn out in short order
also NOT normally a latching relay
normal operation would have included a diode based isolator to do the battery charging and a light duty starter type solenoid/relay for the emg start
you can change this system back to factory, but i see no problem with it the way it is , Except for remembering to push the Button to start the process
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
