ksg5000
Mar 20, 2014Explorer II
In my Fleetwood Jamboree the isolator solenoid should engage when you turn the ignition key - you may have wiring or fuse issue. When I had similar problem I just ran a wire from an empty slot in fuse box through fire wall grommet to the solenoid - the fuse slot of use energized with key turning so it was a quick/inexpensive fix.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
