MEXICOWANDERER
Mar 21, 2014Explorer
A common 11880 steel can Ford type "solenoid" with silver contacts and a 36 ohm coil will instantly fail if a 200+ ampere load is applied across the load contacts.
A five dollar phenolic case Ford starter solenoid is rated for 800 amperes make or break for thousands of cycles. But with a 2.0+ ohm coil is will overheat after a few minutes and fail.
The tower-type Trombetta solenoid is generically referred to as an "Essex Type" solenoid. They are a definite design improvement over the Ford style solenoid.
To avoid make and break flashover deterioration of the contacts, serious solenoids are mercury filled.
Some posters are missing the point. A solenoid has a definite design limit on capacity. Make and break flashover is the major cause of solenoid contact failure.
NUMBER OF CYCLES, make and break at load is a crucial value.
Gear reduction (planetary gears) is becoming more common and it is needed. When did Chevrolet and Ford 454 and V10 engines switch to planetary gear reduction starter motors?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
