YC_1
Feb 27, 2017Nomad
If you are not getting voltage at the output of the alternator and you have an external regulator you need to see what is on the field connector. If it has an internal regulator the alternator is kaput. It should be putting out plenty of voltage.
Another setup uses an external sense wire that has a fuse. You should be able to look up the alternator replacement based on the chassis.
May auto part stores will check your alternator for free.
