dougrainer
Apr 13, 2022Nomad
BFL13 wrote:
OP has one wire on his but that connects to three. One of the three must be from the house. Could check if Emerg start works.
Besides the ignition wire block fuse that wire must go to that connector as one of the three. Check connection too?
What is the third wire?
His problem is, he thinks the Alternator and its wiring are involved. NOT SO. The Tiffin charge solenoids wires are Tiffin installed and have nothing to do with the Alt wires. There are 2 usually 4 or 6 gauge wires. 1 for each large post on the solenoid. Those go to the Pos of the chassis and Coach battery. The center post goes to the Ign controlled Tiffin added wire. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
