DrewE
Nov 20, 2017Explorer III
When it's not working, check the voltage of the wire to the NC connection of the boost switch (from a run/accessory circuit in the chassis). If there's proper voltage there, then the problem pretty much has to be the switch itself. If there isn't power on that wire, then trace it back and see where it disappears. If it's too hard to trace, you could run another wire from some other reasonable location...and make a note of it in your literature for next time.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
