full_mosey
Jan 06, 2016Explorer
Gerald55 wrote:
OK, the need for high amp recharges was news to me. Or is this basically another way of saying that AGMs do need equalization? ...
No. Equalization is a flooded(FLA) thing; meaning to use excess VOLTS to force electrolysis so that the stratified acid is re-stirred EQUALLY throughout the liquid.
As to 'the need' for high Amp charging, there is partial truth to that. The lowest actual mfgrs spec I have seen is to limit Amps to 30% of the 20hr rating. The highest I have seen is unlimited Amps. Some of this is lawyer talk and some is marketing talk.
AGMs do benefit from temp comp chargers. These chargers limit Volts by reading the battery temperature via a probe. IMHO, the purpose is to maximize Amps while at the same time keeping Volts below electrolysis. Allowing electrolysis is simply a waste of energy in an AGM and results in slower charging.
Maximum voltage 15.6 volts. No current limit as long as battery temperature remains below 125°F (51.7°C). Charge until current drops below 1 amp.
HTH;
John
