Gjac
Jan 17, 2018Explorer III
BFL13 wrote:Ok so I should have divided by DC volts not AC volts. So that means with my MSW 1000 watt inverter I should be able to charge my house batteries with my 40 amp B&D charger while in route to the next campsite right?
A "700 watt charger" probably has PF of 0.7, so that is 1000 VA for the inverter to supply.
If the charger is set to 14.8v DC and is 85% efficient (typical) output watts is 595 and at 14.8v, amps would be 40.2.
