pianotuna's avatar
pianotuna
Nomad III
Apr 08, 2015
aluminum ion battery
Energy density about the same as lead acid. 7500 cycle life with rapid charging
aluminum ion
  • Apparently no one saw the actual story on this technology. It's in an engineering lab at a major university. The capacity equals that of a LiPo without the risk of catching fire, and it's CHARGE rate is well over 50C.. I easily pull that on my helicopter, so that's old news for a discharge rate, but charge is apparently a different challenge. They didn't talk any further about the technology since this was a generic news story, but it's absolutely real.
  • I'm looking forward to seeing that. If it is the same energy density per volume as lead/acid, then I'd jump to it for safety reasons.
    If it has more energy density, it only makes it more attractive.
    Even if it had less energy density, for large storage battery applications, this technology will be useful.
    I do see a lot of new battery technologies... I just hope something pans out. As of now, we have lead/acid, and lithium. The biggest problem with Li based batteries is that it needs a very sophisticated charge and discharge controller that monitors/controls all amperage/voltage coming in and out. Without this... boom.
  • Hi mlts,
    I suspect it will have many of the same attributes as LI--where the battery bank does NOT need to be taken to 100% and where 80%discharges are available.
    The depth of discharge essentially increases useable capacity by 30% over the best lead acid formats.
    Unfortunately, my oldest bank is now 9 and showing its age, so I guess I'll be looking for cheap 12 volt bats soon enough.
  • too me "mass" means size/volume, the same cubic inches of Alu will weight less than the same volume of Lead
    density is weight.. so the same density, will mean a battery that is physically larger for the same amp hours
    lithium has the advantage of more amp hours for less weight in any physical size so far
    hopefully the New Alu technology will have cross over characteristics
    more power than lead for less weight in the same pkg, with less cost than lithium
  • About a year or two ago, I read about a fuel cell which turned aluminum into aluminum oxide (also called an aluminum-air battery although it is not rechargable). It has a lot of energy density, but has to be replaced (the aluminum oxide has to be put in with the piles of bauxite.) This would be useful for something that puts out watts over time to keep the batteries topped off, in addition to solar.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
