time2roll
Jul 23, 2013Nomad
First you need to discover if the ducting is even connected. Then verify the in vs out is properly separated in the inside plenum. Then get an a/c thermometer to check in vs out temperature. I believe you should have at least 20 degree drop.
Working well I would think you could get 15 to 25 lower than outdoors.
Now if you arrived with a hot RV it may not really cool until an hour after the sun goes down. The next day is the real test. Set the temp at 70 or less at sunup and see how it holds.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
