I_am_still_wayn
Jul 23, 2013Explorer
herefishy wrote:
Our 5er will only cool to about 9 degrees less than outside - is that all the rest of you get?? Or do I need another air conditioner?
Simple things first: make sure the ducts are properly connected to the A/C and all of the A/C's output is being properly distributed.
Next realize that a RV with minimal insulation parked in direct sunlight with ambient temperatures 90 degrees plus puts a heat load that any 13,500 BTU or even 15,000 BTU A/C will not overcome. You will need 3 maybe even 4 A/C's to overcome that heat load.
Your one A/C is doing a pretty good job under those circumstances reducing the temps by 9 degrees.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
