- dbblsExplorerSounds like you need another AC. Trailers over 35 feet benefit from a second air. It helps to park in the shade but if temps are in the high 90's a second AC is necessary. Also helps to start cooling early in the morning before the trailer gets hot. Not possible if you arrive at the campground in the heat of the day.
- RJsfishinExplorerIf 91 is too hot for you on a 100 degree day, then yep, you need more A/C
I don't know if I could do better than 9 degrees w/ only 1 A/C running in my 31 ft MH
Having RV issues? Connect with others who have been in your shoes.24,334 PostsLatest Activity: Nov 09, 2025
