RJsfishin
May 24, 2017Explorer
Your voltage measurement should be taken between the positive and the negative wires. The negative is the same as the ground. The negative is,....or should be grounded to the frame in one or more places.
If you measure between the positive wire at the bulb and the frame, you should see 12 volts !! If you don't, then the negative does not have a good connection to the frame, in one or more places.
This is something that is so simple, but like always, some are making it so difficult.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
