Must be the same one I got:
http://www.ebay.ca/itm/DC-0-300V-200A-Shunt-Voltage-Current-Panel-Meter-Digital-LED-Voltmeter-Ammeter-/271729368180?hash=item3f44551c74:g:~~0AAOSwc0FUqBWSNote the display resolution is 1 amp. First you have to get the festering thing to show any amps at all! Landyacht warned about that. I get sporadic readings of amps, mostly says zero. Not sure what the matter is --connections ok.
Do I need to use fatter wire from display to shunt for the amps to read anything? The Tri was with a 500a shunt- this is a 200. I am using the same wire the Trimetric has at that distance (15 ft?) from the shunt. I got the voltage calibrated easily enough.
