Gjac's avatar
Gjac
Explorer III
Nov 22, 2015
Ammeter/ Volt meter adjustment
I installed a cheap meter to read volts and amps sometime ago along with a shunt. There are two pots on the meter one for volts and one for amps. The volts I set with my volt meter but the amps I can figure the best way to adjust it. I don't have another ammeter to check it with. It only reads 5 amps when my 2 6v GC batteries are at 50% SOC with a 180 amp alternator so I am thinking either my meter is off or something is off with my charging wiring. Has anyone adjusted these meters using the 12v lights or another simple way without another ammeter?
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
