SidecarFlip
Aug 10, 2018Explorer III
Captain_Happy wrote:
I've got a side by side Domectic in my 40 foot 5th wheel that setting on my rV lot. It's 2003 model, and yes it still works. But just before I left to go on this trip I on it was starting to act up (like not holding temps). So when I return I'll probably take it out and install a residential unit I found at Home Depot that'll side right in. Just have to fill in on the sides, and some trim on the top.
A residential unit don't work for me because I only camp disbursed. Residential compressor units, compressors are either all or nothing. That is, the compressors don't adjust to cooling load, they run at 100% output until the set point is reached and then shut down completely until the set point is exceeded by 'x' number of dergree's and then they start again, at 100% output.
A Secop/Danfoss compressor is a duty cycle compressor. It modulates it's capacity to cool based on compartment temperature so it's rarely running at 100% capacity and a Secop compressor has been designed to be more efficient to begin with. A typical Secop/Danfoss compressor pulls less than 5 amps at 100% duty cycle and most time is pulling less than 2 amps. An ammonia fridge with auxillary cooling fans is approaching that and it's basically all the time.
I've read many comments on the net where people are running Secop/Danfoss units using a single house battery and 150 watts of solar backup.
Not advocating for one, only presenting the pro's and cons. In my case, I'll be refitting this winter anyway.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
