SidecarFlip
Aug 10, 2018Explorer III
mike-s wrote:SidecarFlip wrote:Hardly environmentally friendly - see here. It has over 1000 times the "global warming potential" of CO2. Better than the old R-12, though.
Big thing for me is the quick cool down, much more consistent temperature control and no hazardous chemicals inside (compressor fridges use enviromentally safe R134.
Ammonia and hydrogen, on the other hand, have very little environmental impact. Concentrated ammonia can be corrosive and toxic, but that's about it unless you dump it on ground/water. A slow leak from an RV fridge isn't a threat. The vast majority of ammonia is made for use as fertilizer.SidecarFlip wrote:Huh? My Dometic RM2652 draws about 0.7 A when running on propane, and I haven't bothered to disconnect the anti-condensation heater between the fridge and freezer. <1 A with the interior fans on. And that's when it's drawing power to keep the gas valve open.
A typical Secop/Danfoss compressor pulls less than 5 amps at 100% duty cycle and most time is pulling less than 2 amps. An ammonia fridge with auxillary cooling fans is approaching that and it's basically all the time.
In as much as I farm, I use granulated 46 Urea and anhydrous all the time so I already know that.
My fridge without any fans might pull 1/10th of an amp but I have 2 in the back cavity up top to pull the air through which is a necessity for me, that is 2 amps and two more inside to circulate the cold air, (another amp or so). A Secop unit pulls around 5 on max duty cycle but substantially less most of the time.
Far as the chemicals in the ammonia fridge, so long as they stay contained it's a non issue just like the 134. It's when they leak, they pose a hazard and can be a flammable mixture as evidenced by the many RV fires from them.
Other nice thing about a Secop unit is it don't have to be level to operate efficiently. No thermo siphon principle to consider. A Danfoss/Secop unit can operate at up to 30 degrees out of level. An ammonia unit cannot.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
