SidecarFlip's avatar
SidecarFlip
Explorer III
Aug 09, 2018
Ammonia Fridges, read an interesting piece a while ago
Read an article concerning ammonia fridges and their relationship to ambient versus internal temperatures.
The article stated that the temperature differential is around 30 degrees internal versus external and it seems to hold water in my testing.
Been running my Dometic on shore power in the side yard (empty). I have adequate airflow over the upper condenser with the correct baffles and 2 120mm muffin fans pulling the air through the backside cavity from the lower intake out through the upper vent and 2 additional muffin fans inside the fridge circulating cold air inside. The fridge is well insulated, I added almost a full roll of unfaced R11 insulation around the entire fridge, between the fridge body and the outer cabinet so I'm as 'efficient' as I can get.
I have a recording remote thermometer in the fridge with the readout outside and I've watched for about a week now and the interior temp averages about 30 degrees colder than ambient, more at night, closer to 50 dergrees differential than during the day when it drops back to around 30
The article I read seems to be correct at around 30 degrees temperature differential.
I think this winter, I'll be pulling the Dometic ammonia fridge and installing another Dometic C series Danfoss Compressor unit in it's place. I have a portable Dometic Cool box I carry in the truck and it has no issue holding whatever temperature I set it at from 30 degrees on up in the fridge section to minus 15 in the freezer section.
  • Our Dometic must have been installed properly as it will stay about 50 degrees cooler than outside temps. Usually it will be about 40 degrees when the outside temp is 90+.
  • Funny.......
    My Dometic RM2862 has been able to hold 5*F/Freezer and 38*F-40*F/Food compartment regardless of outside temps. (been in 110*F temps and in high humidity)
    And it doesn't even have fans.
    Course it was properly installed with less then 1" rear clearance, 0" clearances top/sides, NO dead air spaces and really good natural draft via roof vent
    Did have cooling issues couple times when we were in 0*F and lower outside temps (winter storm/snow) but that was easily resolved with the use of a 60W light bulb in lower section of outside compartment
  • My Dometic stays sufficiently cold all the time. When it's over 90 outside and my a/c can barely maintain 80, the refer is having no problem.
  • I'm guessing that's 30C (54F), and for the refrigerator section, not the freezer. A 30F differential would mean a 60F fridge when it's 90F outside. And even that seems low. Ours does way better than that.
  • I'll see if I can verify your numbers today as it will be pretty hot here. 2018 08 09
    Please let us know how the swap to Dometic Danfoss goes. Prices would be nice to have.
    Do you still have a link to the article?
