4aSong's avatar
4aSong
Amp Hour question
As most of you are aware I just received my Renogy 100w Suitcase Solar and have a question relating to the Viewstar VS1024BN controller.
When setting proper battery size and type the controller has a rated value field for the Amp Hours which I cannot locate on either of my 12 volt Interstate group 24 (HD-24-DP) batteries.
I called Renogy and they said to set it at 45AH which I have done but I cannot find any information on where the 45AH they recommended came from.
I have looked everywhere and the only information I can find is 405CCA and 505MCA but cannot find the Amp Hours for these batteries even checked labeling on the batteries and no AH posted on them.
I would guess that these batteries are not a true deep cycle battery is why no Amp Hours are posted but I may be wrong.
Can anyone help me out on what the controller Amp Hour setting should be set at? (is 45AH correct?). I want to make sure that my solar controller is set up properly.
