NinerBikes
Jul 06, 2014Explorer
1 - Projected Amp Hours for 24 hours (amp hour worksheet): 30-45, depending on how much TV I watch with the inverter running.
2 - Current # of batteries: 1
3 - Current # of Amp Hours [AH] your batteries have (or Reserve Capacity [RC]): 150 ah, although the batteries age makes it closer probably to 135 or 140.
4 - Battery Voltage (6 or 12): 12V... Trojan T-1275 sweeper battery.
5 - How long do your batteries last based on #1: 2 days.
6 - How long each day do you run your generator to get "recharged": With a 33 amp power supply unit set at 15.0v at the battery, usually 50 minutes to an hour and 15 minutes.
7 - Provide any other info like if you use solar and how you recharge, etc.:
If using my portable solar panel that I aim 3 or 4x a day at the sun, that charges at a 6.6 amp rate, 120W in June, I am charged by 11-12 noon, most days, in June. Again I use an adjustable charge controller and set the voltage for 15.0V at the battery terminal.
I always, when boondocking, use adjustable voltage chargers, and I almost always set for 15.0V, if day time temps are around no more than 75 or 80F.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
