bill257
Aug 25, 2018Explorer
Amp L Start
I have a question about Amp L Start wiring connection.Two positive wires will connected one each to positive side of chassis and House battery.While ground wire will be grounded.Now I want to install ...
bill257 wrote:
I have a question about Amp L Start wiring connection.Two positive wires will connected one each to positive side of chassis and House battery.While ground wire will be grounded.Now I want to install Amp L Start under the hood near chassis battery and will use the installed relay to attach the two positive wires from Amp L Start.I did not see any ground terminal under the hood so where should I attach the ground wire.Can I attach it to the negative terminal of the chassis battery.
