I have a question about Amp L Start wiring connection.Two positive wires will connected one each to positive side of chassis and House battery.While ground wire will be grounded.Now I want to install ...
When I installed a Trik-L-Start on my previous RV, I used sheet metal screws to screw it to the sheet metal of the storage compartment. I just put the ground wire around one of the sheet metal screws and let the sheet metal ground it to the frame. That ground wire isn't carrying significant current, it is just there so the electronics in the device will work.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
