I have a question about Amp L Start wiring connection.Two positive wires will connected one each to positive side of chassis and House battery.While ground wire will be grounded.Now I want to install ...
As I said voltage is 13.6 at the house battery.I am thinking Amp L Start is not sensing house battery voltage so not charging the chassis battery.I need to find the relay or solenoid for proper connection OR connect directly to the positive terminal of house and chassis battery.If I install the ALS under the hood than I have to take about 15 feet wire under the Rig to the house batter which is located under the steps at the middle entry door.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
