jodeb720
Aug 31, 2017Explorer
Amp Rating
Ok - I thought I understood electricity ratings (watts, volts, amps). I know volts and undestand watts is a measure of work - but amps are a capacity. So when a motor has a rating of 12volts and...
jodeb720 wrote:
So my expectation is I could get a 12 amp hour battery (12 Volts) and I could use the winch to pull a motorcycle up a ramp onto the back o my 5er and using the winch (not at maximum load) I'd use about 2 amps of the battery capacity.
Once the bike is in place, i'd recharge the batter to full capacity.
So - 12 Ah battery would suffice for this?
As we get older, things seem to get heavier and we look to use leverage to make things easier.
In this case, I'm looking for those wild electrons to help me out.
And by the way, thank all of you for the help in getting this sorted out. I really appreciate the clarity.
Josh
