jodeb720
Aug 31, 2017Explorer
Amp Rating
Ok - I thought I understood electricity ratings (watts, volts, amps). I know volts and undestand watts is a measure of work - but amps are a capacity. So when a motor has a rating of 12volts and...
jodeb720 wrote:The only issue I have is you are draining the battery at 1C+ and is very fast discharge. Voltage may sag and at this rate the battery rated at 12 amp/hrs may only give half the power before it gets to 10.5 volts. The faster you discharge the less energy you get. Most ratings of capacity is over a 20 hour rate.
This all goes back to me using a 12 volt winch with a 12 amp rating - so if i'm sizing a battery and I expect the motor to run for no more than 10 minutes then i'd use 2 amps if amps are measured per hour.
What am I missing?
