jodeb720
Aug 31, 2017Explorer
Amp Rating
Ok - I thought I understood electricity ratings (watts, volts, amps).
I know volts and undestand watts is a measure of work - but amps are a capacity.
So when a motor has a rating of 12volts and 12 amps are the amps consumped of amps over an hour (60 minutes)? or is that a constant draw of amps per minute?
If it were watts (it would be volts x amps = watts or in this case 144 watts) - but again, watts are a measure of work - not a capacity or a rating of wires.
This all goes back to me using a 12 volt winch with a 12 amp rating - so if i'm sizing a battery and I expect the motor to run for no more than 10 minutes then i'd use 2 amps if amps are measured per hour.
What am I missing?
Forgive my ignorance, but it's better to ask and understand it than spend money foolishly.
Thanks in advance
Josh
What am I missing?
Thanks in advance
Josh
