mike-s wrote:
ScottG wrote:
Someone else said it had to do with ohms law - it doesn't. It is soley the heat caused by current that melts the fuse.
Those that are suggesting voltage has something to do with it need to read up on the current/coulombs relationship with special attention to what is not included.
As I said above, an AGS-30 fuse will have a voltage drop of about 0.12 V @ 30 A current. That works out using Joule's Law (which is commonly combined into Ohm's law), to be 3.6 W which the fuse has to dissipate. Go to 100 A, and you're closer to 100 W, which melts the link in under a second.
But yes, the circuit voltage doesn't make any difference to when the fuse blows, only the current.
To that end, I've seen where a person put way too small of a fuse in a circuit and while the current was insufficient to blow said fuse, the fuse acted as a current limiting resistor and limited the divices output.
