tarnold's avatar
tarnold
Amps are amps...right?
Be nice ok? Size of wire determines current capacity (amps) as I believe. Recently had to replace a 30 amp fuse(U shaped). Had small size about same as a dime but needed next larger, about size of a nickel. Went to Autozone and got what I needed. They had same style that was about the size of a 50 cent piece, if you can remember what they look like. All 30 amp, so question, why the much different physical sizes, if all are still 30 amp rated?
  • The ampere rating is based on melting element inside the fuse case and the connecting tabs. Fuse case is plastic and has no bearing ion rating.
