HiTech
May 20, 2013Explorer
I am about 70 percent sure this correctly indicates recombining of hydrogen and oxygen internally in the catalyst at an accelerated rate, before release of gas by the valve. I just reproduced it.
Temp works to control outgassimg but is the crudest indicator and generates many bubbles after removing power. Water over valves - fewer bubbles but still more than I want. Multidigit jump in hundredths of amps up and down, no bubbles but same situations that generate bubbles, such as running voltage up to charging voltage on nearly full battery.
I am happy. It was a good day for useable experimental results.
Jim
Jim
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
